Activity Forums Adobe Premiere Pro Re: S.O.S…. Calling Peter Garaway and Kevin Monahan
  • Re: S.O.S…. Calling Peter Garaway and Kevin Monahan
    Posted by Steve Martin on November 5, 2013 at 12:20 am
    Good evening gentlemen,
    You guys have been really active on this forum and I’m hoping you can help on this one. I’ve been trying to find a solution to a problem connecting a Win7 machine to a shared media server and haven’t gotten any responses yet. My original post is below. Any thoughts on what might be causing this?
    Perhaps you can pass this along to a brilliant Adobe engineer?
    thanks,
    Steve
    Hi –
    We are using Adobe CC Premiere on both MAC OS X 10.8 and a single Window 7 machine. All the computers are on a MAC os X Server network with RAID. The Macs connect to the OS X Server using Apple AFP (via 10G switch), and everything is working fine.
    However the single Win 7 machine (also running Adobe CC) is having great problems. We are using Thursby DAVE on the OS X Server to provide a working SMB protocol to the Win 7 machine, to allow for connection.
    We can map the network drive (The Mac shared volume) without issue, and we can open up files in Premiere, and play the files without issue. However, when we try to import footage, or browse folders thru the media browser, everything slows down to a crawl on the Win 7 machine. Once the connection is made successfully, it works fine thoughout the session. However, if I attempt to grab media from another folder on the shared volume, then everything becomes very slow again, and even the folder that was playing back fine previously, is now very slow (skipped frames, stuttered playback, etc…)
    Ever since installing Thursby DAVE (the .smb protocol for OS X), I can no longer import .mov files from the shared network volume.
    SO, using an OS X Server as a shared storage device for these systems (which work perfectly with other Mac’s and Apple AFP) – are there any known issues using an .smb connected machine with Adobe CC to an Apple OS X network ? As you may know, the native .smb that Apple provides in OS X Lion and OS X Mountain Lion does not work, so I am forced to use Thursby DAVE as the .smb protocol for this application.
    Any advice would be greatly appreciated.
    Production is fun – but lets not forget: Nobody ever died on the video table!
    http://www.OmniNewMedia.com
    http://www.GreenSlateStudios.com
    Steve Martin replied 12 years, 5 months ago 3 Members · 5 Replies
  • Walter Soyka
    November 5, 2013 at 6:49 pm
    Is this a home-brew shared storage setup, or do you have a vendor you can turn to for more support?
    I don’t have any experience with this configuration — but I wonder if you’d get better results installing Samba instead of DAVE for SMB on the server, or upgrading the server to Mavericks for its built-in SMB2 support. (Either way, I’d image the server as-is now for quick recovery in case it doesn’t work.)
    Walter Soyka
  • Kevin Monahan
    November 5, 2013 at 8:39 pm
    Hi Steve,
    Yes, the VAR that set up your system would probably be the first person to talk to, if you have that support.
    Here’s what we’ve said in the past:
    Premiere Pro can work with network storage if it’s mounted as a network volume (Mac OS) or mapped drive (Windows), and the OS-level device driver does not mark the volume as removable.
    That said, Premiere Pro itself doesn’t have any locking features so it’s not set up to be used by multiple users at the same time. It is suggested that if you are going to have multiple users, split up the project into several smaller projects and then import all the sequences into a master project when completed. It is recommended that all systems are locked to the same time of day to prevent reconforming of media files.
    We do know that people want to work on shared projects, that is why we are developing Adobe Anywhere. I understand that, currently, Adobe Anywhere is not a solution for absolutely everyone looking to work in a shared environment. What I do have (although for CS6) is this white paper to see considerations on working with Premiere Pro in a SAN environment: https://www.bit.ly/SQQudc
    I hope it helps.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Steve Martin
    November 7, 2013 at 5:07 pm
    Walter and Kevin,
    Thanks so much for your response. Yes, we are working with an engineer (well know and respected) but most of his experience has been in working with Macs.
    A little over a year ago when we made the hard switch to CS6 from FCP7, we thought we’d build a Win7 workstation as a test to see how we liked it. Overall, it worked quite well when it had local storage.
    A few weeks ago we decided to pull the trigger to have the engineer build the same shared storage system that he’s installed for numerous facilities. Everything is well with all the Mac workstations, but the Win7 is having the issues I outlined below.
    Also Kevin, I may have given you the impression that we’re sharing projects. We are not. We are only sharing the media. Projects are integrated by importing timelines as you outlined in your post and it works nicely. The issue we are having is that the Win7 has “difficulty” connecting to the server – but ONLY within Adobe apps (like PP, PS & AE). It connects just fine through Windows Explorer and other non-adobe apps.
    I suspect it has something to do with the dynamic link server (or whatever Adobe calls it). For example, even on a mac, if I use the media browser to navigate to a new folder (to import or re-link footage for example), at the moment I open a folder to reveal items inside, there is a slight hesitation and sometimes a spinning beach ball for a few seconds before it opens the folder.
    That’s what is happening on the Win7 machine. Except that it can take as long as 3 or minutes before it opens. Sometimes it never opens. Once it opens however and you successfully import or relink the media, it works dandy. You can even close the project, shut down the computer and when you re-open the session, it works perfect.
    However, if you try to navigate to a new folder, you’re back to square one. It takes forever to connect (if at all) and if you bail out and don’t let it finish connecting, the media in the previous folder that had worked perfectly, is also stuttered and skipping frames. Very odd…
    I’ll check out the white paper you mentioned and share with our engineer to see if that offers any insight.
    I guess if we can’t make it work, we’ll have considered the Windows experiment a bust and simply replace it with another Mac 🙁
  • Walter Soyka
    November 7, 2013 at 6:36 pm
    [Steve Martin] “The issue we are having is that the Win7 has “difficulty” connecting to the server – but ONLY within Adobe apps (like PP, PS & AE). It connects just fine through Windows Explorer and other non-adobe apps.”
    Bit of a shot in the dark, but have you tried NFS instead of SMB?
    Walter Soyka
  • Steve Martin
    November 11, 2013 at 4:55 pm
    The resolution was upgrade the MacOS media server to 10.9 Mav and use the new SMB2. Works nicely now! Thanks for the tips and advise!!
