Activity Forums Adobe After Effects Re: Shatter
  • Re: Shatter
    Posted by Avrohom Kohn on August 12, 2005 at 4:47 pm
    I have a small layer to which i have applied the shatter effect, but the particles get cut off on the layer’s edge (which is normal), I applied the “grow bounds” effect, to get the pieces to stay on screen till they fall out on the bottom, but that didn’t seem to work, (nothing happened), could anyone tell me how to make the pieces fall outside of the layer’s boundries?
    Any help appreciated,
    thanx
    -A.N.
    Avrohom Kohn replied 21 years, 1 month ago 2 Members · 2 Replies
  • Steve Roberts
    August 12, 2005 at 5:11 pm
    You should move the grow bounds effect above the shatter effect in the effects palette so it’s applied before the shatter.
    Steve
  • Avrohom Kohn
    August 12, 2005 at 7:07 pm
    Thanks, Steve.
    Actually, as i was typing the first message i thought of that and tried it, but didn’t see any result (cause i wasn’t far enough in to the timeline), now that you mentioned it i gave it a try, and it worked.
    thanks again,
    -A.N.
