Activity Forums Blackmagic Design Re : Sdi to Sdi workflow
  • Re : Sdi to Sdi workflow
    Posted by Allanjackson on December 6, 2005 at 6:55 am
    Hey Guys,
    Just recently got my multibridge SD for Final Cut Pro editing suites everything works fine here from analog to digital workflow and viceversa, but Sdi to Sdi dosen’t happen.
    With Multibridge Sd we are using Decklink Plus card,For monitoring we are using component.We are facing problem on editing to tape where we cannot monitor the mastering(Video & Audio)in our editing suites.
    What I have Missed?
    Allan
    Andrew Mcleod replied 20 years, 9 months ago 2 Members · 1 Reply
  • Andrew Mcleod
    December 7, 2005 at 5:21 am
    Multbridge SD is capable of monitoring via Composite while the Component is being sent to a Deck.
    This would permit monitoring of the output at the Multibridge.
    Additionally If you want to monitor what is being sent to the deck, use the monitoring option from the deck.
    SDI to SDI option is available in HD Multibridges.
    Andrew McLeod
    Blackmagic Design
