Activity › Forums › Avid Media Composer › re-scsi- the plot thickens
  • re-scsi- the plot thickens
    Posted by Geraint Pari huws on April 6, 2006 at 10:42 am
    Have tried every combination of cable/drive/scsi channel, same problem, hardware all seems ok,
    still probs once I exceed more than 6 drives, or add more than one new drive…
    however, all seems ok if I boot in safe mode, so not a harware issue…
    Any ideas what software/driver may be causing the problem, Avid STart up??????
    Geraint Pari huws replied 20 years, 6 months ago 2 Members · 2 Replies
  • Bob Zelin
    April 6, 2006 at 11:02 pm
    well, you know the answer now – but you won’t want to do it. Start from Zero – reinstall the OS (clean), check your drives (which will probalby be ok), and then install the AVID software.
    bob Zelin
  • Geraint Pari huws
    April 7, 2006 at 8:51 am
    luckily I think I’ve cracked it bob, conflicting drive letters…
