Activity Forums Adobe After Effects Re-Scaling Position Key Frames When Changing Comp Size?
  • Re-Scaling Position Key Frames When Changing Comp Size?
    Posted by Jay Lee on May 28, 2005 at 12:32 am
    Good afternoon all,
    I am working on some high res stills sequences in Premier Pro that have been rendered out of AE as proxy DV files. The original full res. comp is 3072 x 2048 and the proxies 720 x 480. From previous experience I understand that AE scales up your proxy to the original comp size but Premiere obviously doesn
    Jay Lee replied 21 years, 3 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    May 28, 2005 at 5:38 am
    There’s a ScaleComp script that you may want to look into. I haven’t had any experience with it but it looks like something that should work for you.
    HTH
    Roland Kahlenberg
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Jay Lee
    May 28, 2005 at 5:59 am
    Good evening Roland,
    Many thanks for your reply. I am not familiar with scripts but shall investigate.
    Cheers,
    Jay
