Activity › Forums › Apple Final Cut Pro › Re: Replacing audio for video already in timeline
  • Joby Anthony jr
    November 30, 2018 at 1:50 pm
    Once a clip is in the timeline, it won’t refresh with changes made to that same clip in the Browser. For those changes to appear, they have to be newly added to the timeline. In some instances, you can just drag the clip from the Browser on top of the clip in the timeline and Replace it. But this won’t work once the clip has been cut on in the Timeline.
    I believe the only instance it’ll work is if you still have the very beginning of a clip intact in the Timeline (Replace from Start). Actually, there’s also a Replace from End (of the clip) as well, so two instances it would work.
    Unless someone else knows of a bit of magic I’m not familiar with for this scenario. But pretty sure the only time the Parent/Child relationship is retained is instances of Multicam clips. And I recall reading somewhere on the forums here recently that many advocate using Multicam clips to sync audio instead of the Synchronize Clips feature, in part, because of the flexibility Multicam clips. If I run across that thread, I’ll add it to the discussion.
    — Joby.
  • Joby Anthony jr
    November 30, 2018 at 2:23 pm
    Joe Marler’s excellent explanation:
    https://forums.creativecow.net/thread/344/52517#52614
    And the link he refers to about Multicam vs. Synchronize:
    https://www.fcpworks.com/sync-or-multicam-clips/
    — Joby.
