Activity Forums Adobe After Effects Re-Rendering NTSC to PAL
  • Re-Rendering NTSC to PAL
    Posted by Farhan Ali on May 11, 2015 at 3:14 pm
    Hello everyone, I’m currently working on a project where I will be working with different resolution elements. My end product will be 1080p HD standalone, no DVD’s or BluRay disc. But during the creation of the project I will be able to render NTSC 29.97 (FPS). By rendering most of the project files in NTSC 29.97 (FPS) and then compiling all the files together and re-rendering them altogether will it affect the end result?
    So basically I’m rendering projects in NTSC 29.97 (FPS) and then compiling them rendering them altogether based for 1080p HD.
    Farhan Ali replied 11 years, 3 months ago 52,825 Members · 2 Replies
  • Farhan Ali
    May 11, 2015 at 6:54 pm
    Hello Dave thanks for you’re response, I will be rendering all my projects in 29.97 but will have to be done in NTSC
    Only 2 small projects have been rendered using PAL 25 hopefully they won’t cause any issues later in the compiling stage. Also, when it comes to rendering I tend to opt for: MPEG2 BluRay changing few settings (Quality, VBR 2 Pass, Use Maximum Render Quality) and tick “Export Video” & “Export Audio”.
    Are the above settings appropriate for my final end project?
  • Farhan Ali
    May 11, 2015 at 9:57 pm
    OK Dave I will try and render the 2 project files again.
    What will happen if I was to render NTSC 29.97 in HD 1080p and play it on PAL TV? The end result will not be on DVD/BluRay Disc just stand alone media file. It should still work on PAL TV’s?
    The reason why I asked is because I don;t want to lose any quality of my end result.
