Activity Forums Apple Final Cut Pro Legacy re-render audio
  • re-render audio
    Posted by Andrei Bocharnikov on November 9, 2005 at 3:06 pm
    i used some audio as background and when i draged it to timeline it became red as if i need to render it and when i am listening timeline i can hear bip sound along red area. then i did render of that part, bip disappeared but sound became mono. It is two chanels but the same and sound in the middle. I did not noticed it immediately and did a lot of editing with such audios.
    how it is came that audio became mono and how to re-render audio to make it stereo.
    thank you very much,
    Andrew
    Mark Fassett replied 20 years, 10 months ago 3 Members · 3 Replies
  • Lee Burrows
    November 9, 2005 at 3:22 pm
    Andrew,
    Highlight the audio in your sequence and then go under Modify and choose stereo pair. This should be checked to make it stereo. If it will not check then perhaps the audio that you imported was not stereo to begin with.
    Good Luck
    Lee
    G5 Mac OS X
    Dual 2.0 GHz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G5 Mac OS X
    Dual 2.3 GHz
    FCP 5.02 Studio
    G-Tech G Raid 500 GBs
    2 – Lacie Drives 200 GBs
  • Andrei Bocharnikov
    November 9, 2005 at 4:15 pm
    Lee, thank you for your quick reply. I have it checked but still it sounds mono. when i play source file in the browser it is stereo, but the same file in the timeline – is mono… very strange and frustrating.
    Andrew
  • Mark Fassett
    November 9, 2005 at 6:38 pm
    yes, I noticed the same thing and never found a fix. My workaround was to drag the audio file back into the sequence and NOT render it.. changing the number of audio tracks in the preferences so it didn’t require a render.
