Activity Forums Adobe After Effects re-render a movie?
  • re-render a movie?
    Posted by Bob Sabiston on July 11, 2010 at 10:30 pm
    Hello,
    Can someone please tell me how to re-render my composition to a movie, the same way as I have just done?
    It is the commonest thing I can imagine wanting to do in AE yet I never have found out how. I render a movie out to quicktime, say Sorenson3 format, change the stretch scale to something, turn on audio, pick a filename, etc. Render it. See a mistake. Fix the mistake, then…
    how to just run that again without having to manually make all those changes again, each one potentially forgotten as I do this over and over?
    many thanks to someone who can tell me!
    This is CS3 I have.
    Bob
    Bob Sabiston replied 16 years, 2 months ago 4 Members · 4 Replies
  • Tudor “ted” jelescu
    July 12, 2010 at 8:34 am
    In the Render Queue select your previous render and hit Ctrl D / Cmnd D (on Mac) to duplicate- this will give you a duplicate of your original settings- re-name if you want to render to a different location.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Walter Soyka
    July 12, 2010 at 5:49 pm
    [Bob Sabiston] “Can someone please tell me how to re-render my composition to a movie, the same way as I have just done? It is the commonest thing I can imagine wanting to do in AE yet I never have found out how. I render a movie out to quicktime, say Sorenson3 format, change the stretch scale to something, turn on audio, pick a filename, etc. Render it. See a mistake. Fix the mistake, then… “
    Ted’s instructions on how to duplicate items in your render sequence are correct.
    I’d suggest, though, that you encode to a lossless format (like Quicktime Animation at 100%, or Quicktime PNG) and use a third-party encoder (like Telestream Episode, Sorenson Squeeze, or Apple Compressor) to create your compressed deliverables. The AE render queue is not capable of multi-pass encoding, which improves compression efficiency and reduces artifacts.
    Sorenson 3 is quite outdated now, and is considered a legacy codec; unless you have a specific requirement for Sorenson 3, you should be able to get much better results in a smaller file with the h.264 codec. If you must deliver Sorenson 3, I’d look at Sorenson Squeeze, which includes the Sorenson 3 professional compressor — a huge quality improvement over the (free) Sorenson 3 Basic encoder included with Quicktime.
    Walter Soyka
  • Joey Burnham
    July 12, 2010 at 6:00 pm
    You can also just create a custom output module. Then your specific settings will appear on the drop down list in the render queue.
    Joey
  • Bob Sabiston
    July 12, 2010 at 6:34 pm
    I’d love to use H.264 but in 5 years or so I’ve never been able to figure out how to get it to reproduce colors correctly. They are always pretty far off, washed out and lighter than the original. It is a shame because it is all Apple will tolerate anymore, pretty much. You would think they would have addressed the problem by now.
    Bob
