Activity Forums Adobe Premiere Pro re: recreating title animation/effects
  • re: recreating title animation/effects
    Posted by Esther Casas on March 6, 2020 at 8:34 pm
    Hi all!
    I have this video as reference to re-create the animated titles and effects on the text. I am a bit rusty on animating titles, so I like to know if there any templates for when the text “HERITAGE” appears rolling down? and also when the letters appear in different colors?
    If no templates, are there any effects in Premier e Pro or After Effects? what are the name of these effects?
    Here is the link to the video: https://vimeo.com/280748214
    Thanks to all!
    Esther.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Esther Casas replied 6 years, 6 months ago 4 Members · 5 Replies
  • Eric Santiago
    March 6, 2020 at 8:48 pm
    Easily done in After Effects not sure about Premiere.
    It could be a 3D effect in Premiere with two or more text on top of each other and off-setting the animation a little.
  • Esther Casas
    March 6, 2020 at 8:50 pm
    hI Eric, thanks for the quick response,
    So if it is easily done in AE, could you describe how you will do the rolling down and changing colors in AE? I am not sure how to do this easily,
    thank you!
  • Jon Doughtie
    March 7, 2020 at 11:14 am
    Create the word you want one time in AE, choose the color, activate 3D, and keyframe the X axis rotation as desired.
    Duplicate that text line, change the color, and offset it to the right by the desired number of frames
    Repeat as needed. Final desired color should be on the top of the composition stack.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Jim Curtis
    March 8, 2020 at 3:05 pm
    You can do this in Pr.
    Create a Sequence that’s at least twice the height of your text. Place the text so that the top is touching the horizontal center-line.
    Put that Sequence (now a Nest) in your master sequence and position it where you want it.
    Apply the Basic 3D effect.
    Animate the Tilt from -90 to 0 degrees.
    Apply a Tint effect and choose a color in both the Black and White color boxes (I prefer Tint for colorizing to the Paint Bucket.).
    Option-drag this Nest to a higher track and delay its start point in time by a few frames.
    Change the tint on the new layer.
    Jim Curtis
    jamesphilipcurtis.com
    MacPro7,1 24-core – 256 GB RAM – AMD Radeon Pro Vega II 32 GB – 10.15.3
  • Esther Casas
    March 8, 2020 at 3:15 pm
    Hi! will try these suggestions, which are great.
    Thank you all!
