Activity Forums Adobe Premiere Pro Re-positioning a clip in the frame after distorting
  • Re-positioning a clip in the frame after distorting
    Posted by Andrew Fuller on May 15, 2017 at 7:11 am
    Hello and thanks for reading my question
    I have a clip and i have applied some lens correction to it. Id like to now re-position it so that I can see some of the bottom part of the frame that has been squished out of view (moving the whole frame upward so that the top part of the frame now goes out of the frame) How would i do this, is there a way to drag is around or a way to make the arrow keys bump it about? Thanks for your time.
    Andrew Fuller replied 9 years, 3 months ago 2 Members · 2 Replies
  • Jon Doughtie
    May 15, 2017 at 1:09 pm
    With the clips selected in the timeline, you will see these control in the Effects tab that will allow you to re-position the clip.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Andrew Fuller
    May 16, 2017 at 1:42 am
    Thankyou so much for your time, whenever i searched for an answer i just got info about repositioning things in the timeline. ow i can move on 🙂
