Activity Forums Apple Final Cut Pro Legacy re: outputting to Panasonic AJ93
  • re: outputting to Panasonic AJ93
    Posted by Manfred Lim on January 1, 2006 at 3:22 pm
    Hi I am having some problem outputting programmes to the AJ93 deck. Understand that it is not an edit deck but it should at least record with remote using the RS 422. Had some success using firewire but sometimes it stops halfway… and no sound when using SDI(Yes,.. a mix setting using firewire). I have not problem using the deck to capture. It is connected using SDI through AJA IO box. RS 422 connected using the AJA. The assembele and edit functions appears greyed out. I have to record manually without using the remote.
    Any help?
    marf
    Walter Biscardi replied 20 years, 8 months ago 2 Members · 4 Replies
  • Manfred Lim
    January 1, 2006 at 3:28 pm
    Sorry forgot to add.. using FCP 5.03 1,8 ghz dual processor G5 on a tiger OS with 2 gig rams. AJA IO box using sanmp raid sytem.
  • Walter Biscardi
    January 1, 2006 at 4:32 pm
    [marflim] “Understand that it is not an edit deck but it should at least record with remote using the RS 422.”
    Not if it is set up like the AJ-HD1200A DVCPro HD deck. RS-422 ONLY works during playback and NOT during record. I can ONLY Edit to Tape to the 1200A using Firewire control. I thought I read somewhere that the 93 is the same way.
    It’s the dumbest ‘feature’ of the 1200A to disable RS-422 during Record, but there you go.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Manfred Lim
    January 2, 2006 at 1:32 pm
    Thanks Walter for the information.
    Wonder with firewire edit to tape… did you use SDI on the Deck or pure firewire input? I had sucess once but had problem later on using pure firewire…was told possible conflict with fire from AJA IO box.
    Happy New Year!
    marf
  • Walter Biscardi
    January 2, 2006 at 1:38 pm
    [marflim] “Wonder with firewire edit to tape… did you use SDI on the Deck or pure firewire input?”
    I use either depending on what I’m doing. Just simply set Device Control to DVCPro Firewire and then you should have deck control during Edit to tape.
