Activity › Forums › Panasonic Cameras › Re: Outputting DVCPROHD 720 30p to Tape
  • Re: Outputting DVCPROHD 720 30p to Tape
    Posted by Arjun Rao on June 6, 2007 at 5:59 pm
    Hello all,
    I would like to know the best way to output 720 30pn (Native mode) shot on the P2 to DVCPROHD Tape.Do the flags transfer onto tape.
    Sincerely,
    Arjun
    Barry Green replied 19 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    June 6, 2007 at 6:04 pm
    30p is 29.97…so it should transfer to tape fine. FCP does not send the flags back to the tape, AFAIK.
    Are you talking output via firewire? Or Capture card?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arjun Rao
    June 6, 2007 at 6:29 pm
    Dear Shane,
    Thank you for your response. We put the p2 clips in a sequence and then output to tape via HD SDI using the Kona 2 card. We were having difficulty outputting to tape via firewire, so switched to HD-SDI. However we are trying to digitize from the tape using firewire but it is not digitizing 720 30p , it is digitizing 720 59.94. Suggestions
    Sincerely,
    Arjun
  • Shane Ross
    June 6, 2007 at 6:47 pm
    Ah…yes. DVCPRO HD on tape always runs at 59.94. The Varicam sets flags so that when FCP captures it, it removes whatever pulldown the flags set…but it is still on the tape at 59.94.
    I don’t think that you can output that footage onto tape with 30p flags…for one because there weren’t any flags to begin with. 30p from the HVX is 29.97, not 59.94 with pulldown….so there are no flags. Even if you captured this 30p footage from tape, with flags, I don’t think that FCP can export those flags.
    So when you go to tape, your footage will be 59.94…that is unavoidable. Because the tape format, as I mentioned, runs at 59.94 only. And no flags can be sent, in my experience (Gary, Walter?).
    We had this issue when shooting this format as B-camera to varicam and not only were the edit systems OLD Avids that could not import P2 footage, but the network wouldn’t accept data files…tape only. So we had to transfer everythign to tape.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arjun Rao
    June 6, 2007 at 7:06 pm
    Dear Shane,
    Thank you for this response.I have now been asked our Series Producer to do a cost benefit analysis for the P2 workflow.(Network is not accepting data files)
    Sincerely,
    Arjun
  • Shane Ross
    June 6, 2007 at 7:12 pm
    Discovery? That is the network that wouldn’t take them from us.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arjun Rao
    June 6, 2007 at 9:19 pm
    Yep. As there is no viable tape based option for the B Camera, we are going to have to work with P2
    Arjun
  • Gary Adcock
    June 6, 2007 at 9:33 pm
    [Shane Ross] “DVCPRO HD on tape always runs at 59.94. The Varicam sets flags so that when FCP captures it, it removes whatever pulldown the flags set…but it is still on the tape at 59.94.”
    Caution
    The varicam can also capture at 60hrz not only 59.94
    the 60hrz setting allows for 25.0 over 60fps captures or true 24.0 content if needed.
    FCP cannot extract VFR frames on the fly, but your Kona card can, FCP needs to run the 59.94 DVCPROHD ( or now 50P for the EU) content thru the software FRC.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Barry Green
    June 7, 2007 at 3:52 am
    Seems like the only problem you’d have with firewire is that FCP isn’t inserting the flags on export, right? If FCP would add the flags then your firewire export should work…
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
