Activity › Forums › Apple Final Cut Pro › Re-linking problem
Re-linking problem
Posted by Lance Bachelder on April 26, 2014 at 6:13 pmWhy can I not re-link to the exact media that was used in the FCP7 cut. XML’d cut into X and cannot re-link to most of the shots and audio – X says does not match the original BUT it is the original!!! Is the a way to override this? What if I wanted to re-link to a different version – my choice – I can’t…
Lance Bachelder
Writer, Editor, Director
Downtown Long Beach, California
https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1Mitch Ives replied 12 years, 4 months ago 4 Members · 11 Replies -
Jeremy Garchow
April 26, 2014 at 6:53 pmYou can relink to corrected media, with caveats.
https://support.apple.com/kb/PH12701
As for why your clips aren’t relinking, what are the steps you took to get to X?
Lance Bachelder
April 26, 2014 at 7:13 pmI used 7toX – the files I’m attempting to relink are the exact same files used in 7 but X says they are not. This is not the first time this has happened. FCPX could also use a “replace” file feature like every other NLE.
Lance Bachelder
https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1 -
Jeremy Garchow
April 26, 2014 at 7:22 pmTry reimporting ONE of clips. Does it relink or bring in a new instance?
You haven’t used Adobe products in the middle of it, have you? XMP can cause problems.
Bret Williams
April 26, 2014 at 7:51 pmYou’re not using a Canon 5D mark III are you?
That could be the culprit. 10.1 recognizes the TC (to do think). So if you didn’t use log and transfer in 7, the TC wouldn’t match.
Previous to 10.1 X didn’t recognize time of day as time code and every clip from canon started with 0.
Now every canon I’ve used still has 0 TC except the 5D mark III. So any projects pre-10.1 exhibit the problem you’re describing. The mark III clips absolutely can’t connect. Projects mixing a mk III, 7D, T4i, etc relink everything but the mk III.
Thankfully just a nuisance since those projects are completed.
Mitch Ives
April 29, 2014 at 5:12 pm[Jeremy Garchow] “You can relink to corrected media, with caveats.
https://support.apple.com/kb/PH12701“
I wish it were that simple. In the process of moving files from the old Mac tower to the new flame throwing Mac Pro, we experienced a linking problem in a project. Remember, these are files from a machine with the identical OS version and the identical version of FCP X. The files are all linked perfectly on the old machine and play perfectly in any project, including a new one made as a test.
Got the following error message:
So, we moved the project and all associated files again. Same problem. Lots of files linked fine, just a group that wouldn’t. Got frustrated after no success with several attempts at manually relinking, so went to sleep. Next morning, made one last attempt at relinking and surprise… some files manually re-linked… the same files that wouldn’t the day before even with a dozen attempts. Still, it was a partial victory, since other files still wouldn’t relink. Just the ones we selected at that first attempt in the morning (maybe you only get one wish each day). Very flaky behavior.
In the end, I had to reimport a whole load of camera files as new clips, and manually reset all the in and out points of the affected clips, and then replace those clips on the timelines. It was like being forced to re-edit these projects. I think I’ll suggest Sheriff Joe use this tactic as a form of punishment for inmates.
So, there is something deep inside FCP X that still isn’t dialed in. No consistency as to what causes the problem, as many older projects relinked just fine. So did newer ones. So did ones made the same week as the problem project. We were careful to keep everything organized and in the same places as on the old machine. We didn’t get creative… just wanted to have the new machine replace the old one.
Mitch Ives
Insight Productions Corp.“Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things.” – Winston Churchill
Mitch Ives
April 29, 2014 at 9:49 pm[Jeremy Garchow] “Perhaps it’s a file extension problem?”
In what way? If it all works fine on the donor machine, what change could have occurred?
Mitch Ives
Jeremy Garchow
April 30, 2014 at 12:16 amIn the way that moving files to a new system can sometimes mess up file extensions due to new prefs.
Also, if you clicked on a file in the relink dialogue, what did it say was incompatible?
It looks like there’s some media that’s managed and not external?
Mitch Ives
April 30, 2014 at 2:35 pm[Jeremy Garchow] “In the way that moving files to a new system can sometimes mess up file extensions due to new prefs.
It looks like there’s some media that’s managed and not external?”
I’m not sure how the extension would be changed. I never change any extensions and I import all media through FCP X. When the file system changed, all projects were updated on the old machine, and everything went flawlessly. As I said this media is linked fine on the old machine.
The fact that I could right-click in the media window, choose Import Media, and point to the very same files on the disk array and have them import as a second instance of those clips, would indicate that the files are all intact.
The error message I posted earlier is the error message I got over and over.
There is a downside to every upside, and this is the sort of thing that happens when you build your world around a database. Lots of upside to this approach, but here’s a downside… if the database isn’t happy, you don’t get to pass Go. I’d like Apple to give us an “I wan’t to take the damned seat belt off” option, where I can force FCP X to link to those files, regardless of what it “thinks”. You know, like TurboTax does, where even though the program thinks it’s smarter than you, you can still override a box and enter a value, when you’re actually smarter than it thinks it is…
Mitch Ives
Jeremy Garchow
April 30, 2014 at 5:56 pm[Mitch Ives] “I’m not sure how the extension would be changed. “
Not changed, deleted. It’s a Finder preference. If you did some sort of file copy and a preference was deleted, sometimes, X can be confused.
[Mitch Ives] “As I said this media is linked fine on the old machine.”
Because it had the correct prefs. The new machine has new/different prefs.
[Mitch Ives] “The error message I posted earlier is the error message I got over and over.”
And when you single click ONE of the files in the relink window, it doesn’t give you anymore information?
[Mitch Ives] “There is a downside to every upside, and this is the sort of thing that happens when you build your world around a database. Lots of upside to this approach, but here’s a downside… if the database isn’t happy, you don’t get to pass Go. “
All NLEs are a database. X’s relink is pretty sensitive, but FCPX will relink to different files as long as there is certain common criteria.
