Activity › Forums › Avid Media Composer › Re-Linking Clips to External Drive
Posted by Alan Callaghan on June 19, 2015 at 5:48 pmHello All,
So I was given a Harddrive with all the media files, and project file from an edit house. When I open open up the provided project file, everything is offline, and is still looking for the ISIS that the edit house was using.
What’s the best method of re-linking all this footage to the new drive?
Thanks for your time, and help!
Alan
Alan Callaghan replied 11 years, 3 months ago 3 Members · 8 Replies -
Ricky Barrow
June 19, 2015 at 6:31 pmMake sure the “Avid MediaFiles” Folder is on the root of the drive. You may need to go into the “MXF” sub-folders and delete the database files. Avid should rebuild and see the files without relinking. I would try this first.
Ricky
Alan Callaghan
June 19, 2015 at 6:43 pmHey Ricky!
Thanks for the tip. I tried deleting the data base files, and made sure the folders are on the root. No luck yet.
Thanks for the response!
Alan
Michael Hancock
June 19, 2015 at 6:57 pmIf it’s Avid media, this has to be the file structure (note the capitalization and spacing):
DRIVE:/Avid MediaFiles/MXF/1/[MEDIA GOES IN NUMBERED FOLDER]
I don’t know how ISIS does it, but I work off an EditShare and it names the media folders based on the user’s computer name. So instead of a 1 folder I see iMacHancock.1 and iMacPostIngest.1 and stuff. So if I take those folders to a local media drive I have to rename the iMacHancock folder to 1 or 2 or 3, etc… If the folder the media is in isn’t a number, Avid won’t scan it.
Michael Hancock
Editor -
Alan Callaghan
June 19, 2015 at 7:04 pmHey Michael!
I appreciate the response. However the files inside the MXF folder are named “1” “2” “3” “4”. There was no added text by the ISIS. I just know it was an ISIS because of the Drive column in the Avid bin.
Right now the folders on the drive are as follows:
Avid MediaFiles
Graphics
2015_Edit (Project file/bins)I have deleted the databases, without success.
thanks for any help everybody!
Alan
Ricky Barrow
June 19, 2015 at 7:07 pmCheck to see if the “media” is actually media that was imported, consolidated or transcoded and not AMA linked only. You should be able to relink no matter what. Highlight all media clips in a bin and choose relink – when doing this you will be offered many choices. I would start with default settings but select your external drive. You may need to play with some of the options when trying to relink. You can relink Sequences as well.
Did Avid rescan the media drive as it was booting after you deleted databases?
Ricky
Ricky Barrow
June 19, 2015 at 7:15 pmHere is a similar thread with answers from verterans:
https://forums.creativecow.net/thread/45/899742#899742Ricky
Alan Callaghan
June 19, 2015 at 7:19 pmThey are MXF files, and not AMA. When I choose “Relink” it never finds the clips. I have trashed the databases and reloaded avid (it takes a minute to re build).
Are there settings in the “Relink” I’m maybe missing?
thanks guys
Alan
Alan Callaghan
June 19, 2015 at 8:05 pmHey All!
I’m all set! I found out the missing footage was on another drive.
Thanks for the responses and tips, I really appreciate it!
Have a great day
Alan
