Re Link
I get this msg when I try to relink my media files. Im lost because I have not changed any formats or where the files are located.
83 name matches were found, but 83 files are not compatible.
Relinked files must have the same media type and similar audio channels as the original files, and must be long enough to cover all the clips that reference the files.Select a single item at a time to get information about why it is not compatible.
All i have done is gone from FCP10 to 10.3 with Mavericks OS does anyone have any type of solution or a work around
