Activity Forums Apple Final Cut Pro Legacy Re: Kona 2 HD Monitoring?
  • Re: Kona 2 HD Monitoring?
    Posted by Otis F on May 23, 2005 at 4:10 pm
    Hello,
    I’ve just received my new Kona 2 with K Box and IO LA. I am monitoring using a 23″HD monitor and a hi res SD CRT monitor. I have loaded the Panasonic HD National Geographic footage and timelines from the disk that comes with FCP. When the playhead is parked you see a still on each monitor but when you hit play neither of the monitors displays a moving image, though they do update when you hit pause. I have had this issue before using DV Pal as the output, but as far as I am aware all the settings are correct. I’m sure this is my ineptitude, but any ideas would be much appreciated.
    Thanks in advance.
    Otis F
    Otis F replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
