Activity Forums VEGAS Pro re-joining clips after split?
  • re-joining clips after split?
    Posted by Dv Memories video on May 15, 2007 at 7:50 pm
    Is there a way to re-join 2 clips together after they have been split, as long as nothing has changed with the in/out points?
    (Not “undo”)
    Terry Esslinger replied 19 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Laszlo Kovacs
    May 15, 2007 at 8:16 pm
    You have the option to group them.
    (They move together)
    OR
    Delete one of the clips and
    resize the other to the original size.
    Hope I could help.
    By(t)e
    K.L.
  • Dv Memories video
    May 15, 2007 at 9:07 pm
    Thanks, guess the delete/resize will do the trick. Sometimes i will rely on splits to separate scenes or whatever. Or i’ll accidently split instead of splat for some unknown reason, not realizing until later.
    In studio, you can select both clips, right click, then “combine clips” and it will join them back together.
  • Gary Kleiner
    May 15, 2007 at 9:13 pm
    [DV Memories Video] ” i will rely on splits to separate scenes or whatever”
    Try using markers or regions for that.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Terry Esslinger
    May 15, 2007 at 9:53 pm
    [DV Memories Video] “re-join 2 clips together after they have been split,”
    I think UltimateS has an unsplit function
  • Edward Troxel
    May 16, 2007 at 2:50 am
    I know Excalibur does. 🙂
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    May 16, 2007 at 3:27 am
    As does Excalibur.
    Gary Kleiner
  • Mike Kujbida
    May 16, 2007 at 9:59 am
    Highlight both clips. Right click and select Open in Trimmer.
    The single (joined) clip will be highlighted.
    If this was part of a larger clip, only this selection will be highlighted.
    Now drag it back to the timeline.
  • Terry Esslinger
    May 16, 2007 at 3:58 pm
    I stand corrected, ot IS Excaliber that has the function. I many times get the two mixed up in my mind as to witch does what. There is some overlap. Great tools both.
