Activity › Forums › Adobe Illustrator › Re: Isolate selected area from an image layer, Illustrator CS6
  • Re: Isolate selected area from an image layer, Illustrator CS6
    Posted by Esther Casas on November 28, 2016 at 3:21 pm
    Hello everyone!
    Ok, I am new in illustrator, I barely use it…but I was given an Illustrator CS6 file that I must edit. I normally work with After Effects so thought it will be easy to work with layers, but I got stuck with something that seemed obvious to me but can’t make it happen…Here it is:
    I want to isolate a certain area from an image. Once I trace the area I want (with Pen tool), Illustrator shows me the “path” , which I can copy and paste into another layer, but it does not isolate the image that is inside it, like it normally happens by default with After Effects. I have been trying to do so but can’t find the way, neither searching online…I am sure there is a very easy way to do this but have no idea where it is…Can somebody tell me how to do this? I work on a Mac.
    Thank you so much!
    Esther.
    Vincent Rosati replied 9 years, 10 months ago 2 Members · 1 Reply
  • Vincent Rosati
    November 29, 2016 at 12:33 am
    I think you want to create a Clipping Mask.
    Select your vector shape and your image, then Object > Clipping Mask > Make.
    Note, the vector must be on top of the image.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
