Activity › Forums › Apple Final Cut Pro Legacy › Re: Internal drive compatibility issues??!!
  • Re: Internal drive compatibility issues??!!
    Posted by Otis F on November 13, 2005 at 2:18 pm
    Hello,
    I’ve just added a second internal 500GB Seagate Barracuda SATA2 7200 16MB HDD to my Dual 2Ghz G5, however it failed to mount after starting up the system. I took the drive back to the supplier who confirmed it wasn’t faulty i.e. it mounted on a PC. I’ve since found out from a response to my post earlier (thanks Nick) that these drives and others are more than likely incompatible. Check out: https://www.xlr8yourmac.com. It would seem that… and now I’m quoting: “the new Seagate SATA 500G comes in 2 versions – one with SSC enabled, one without SSC. Users want to get the non-SSC version of the drive.”
    Now don’t ask me what SSC is, I know not, all I want to know is how would I find out which model of Seagate is the non-SSC version. I buy my drives & peripherals from a PC supplier and I’m sure they wouldn’t have a clue about such things. Or failing that which specific drive should I get for the the secondary mounting? I went for the Seagate initially because of the size (500GB), price (250 quid-sterling), buffer size (16mb), and warranty (5 years).
    Thanks in advance for any help
    Otis F
    Mitchji replied 20 years, 10 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    November 13, 2005 at 2:51 pm
    Have you contacted Segate? Might email them…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Otis F
    November 13, 2005 at 3:44 pm
    Jerry,
    Yes I’ve just emailed them with pretty much the same post, so I’ll wait for their response, meanwhile I may just swop it for an external firewire?
    Cheers
    Otis F
  • Jerry Hofmann
    November 13, 2005 at 6:30 pm
    I’m having great luck with my Hitachi SATA… was a 7200 RPM 8mb disk cache unit…
    Jerry
  • Mitchji
    November 13, 2005 at 8:06 pm
    [Jerry Hofmann] “I’m having great luck with my Hitachi SATA… was a 7200 RPM 8mb disk cache unit…”
    Some models of Hitachi have SSC turned on also. Barefeats has a list of model numbers.
    Best Wishes,
    Mitch
