Activity Forums Adobe Premiere Pro “Re-interlacing” Canon 5D mk II
  • “Re-interlacing” Canon 5D mk II
    Posted by Jacob Waage on March 18, 2011 at 2:32 pm
    Hey!
    I just did some video on a Canon 5D and it will be broadcasted on a regional television station in a few weeks. But I need to make my recordings look a bit more “smooth” – I know, that it’s not possible to get the smoothness of an original 50i signal, and that’s not my goal, but it must be possible to make the progressive look just a little less… progressive..??
    I’ve got Premiere Pro CS5 and Avid…
    Thanks…
    Jacob
    Rafael Amador replied 15 years, 6 months ago 3 Members · 2 Replies
  • Ann Bens
    March 18, 2011 at 6:05 pm
    Drop your footage in a 50i timeline.
  • Rafael Amador
    March 18, 2011 at 8:18 pm
    [Ann Bens] “Drop your footage in a 50i timeline.”
    That wouldn’t makes nothing. Would be no movement between both fields of the same frame. Basically you would get p25psf, so still Progressive.
    You need some software that makes a real re-interlacing. If you want 50 interlaced pictures out of 25 progressive, first you have to create 25 new in-between pictures; then you take one field from each.
    This is the only tool I know to do this:
    https://www.revisionfx.com/products/fieldskit/
    rafael
    http://www.nagavideo.com
