Activity Forums Blackmagic Design RE: Intensity Uncompressed
  • RE: Intensity Uncompressed
    Posted by Tilford Bartman on February 14, 2009 at 10:09 pm
    Just wonder if someone could confirm or comment on the following.
    1) My understanding is that there is no increase in qualify to taking video from HDV tape uncompresed through the Intensity’s HDMI to your hard drive, VS taking it from the HDV tape via Fire Wire in a compressed format like Cinform,Canopus HQ, etc. You only get increased quality if you take the video live through the camera’s imaging device before compression?
    2) If your going to edit 8 bit uncompressed HD in Premiere, with maximum two tracks of video, titles, transitions, music in the background etc., what should be the transfer rate of your drive system to be able to do this with some head room?
    Tilford Bartman
    Brett Howe replied 17 years, 7 months ago 3 Members · 2 Replies
  • Tracy Peterson
    February 15, 2009 at 10:57 pm
    1.) yes.
    2.) the transfer rate should exceed the bitrate of the video, I would imagine. I don’t have an exact answer here.
    Tracy Peterson
    http://www.onetwomany.com
  • Brett Howe
    February 16, 2009 at 10:54 pm
    Blackmagic has some nformation on their website regarding Raids and bitrates for HD video. It’s worth a look there.
    What I would say is it shouldn’t be all bundled together.
    Keep your Audio Files and Graphic elements etc on a seperate drive.
    If you have lots of assets on the same drive, in different locations, the heads spend half the time (I exagerate) seeking out the assets, and you loose your sustained data rate speed.
    as for the first question. Once the vision goes to tape on a Z1, it is compressed to MPEG2 25 (50i). There is definately no point in capturing this uncompressed, unless you are looking to avoid that seemingly unnavoidable lag that comes with long format Native HDV edits. The upside is it is no harder on your drive speed than DV! As long as you have plenty of RAM and CPU to handle the decoding, I’d go with native.
    I have just completed a DOCO shot on Z1’s. Captured as native, there were about 16 hours or so of footage, that took up almost 200 gig on my raid.
    I cut the job in a BM project, and imported the mpeg footage. It worked brilliantly, and I still had a BM HD preview. Although on fast movement the Z1’s are prone to SOFTEN somewhat, the footage was generally excellent, and the client was very happy with the finished piece for broadcast.
    Brett Howe
    Creative Director / Producer
    Brave Vision Pty Ltd
