Activity › Forums › Apple Final Cut Pro Legacy › Re-Installation of FCS 3
  • Re-Installation of FCS 3
    Posted by Sascha Engel on January 20, 2012 at 3:17 pm
    Hallo Everybody,
    I installed recently FCS3 over my existing FCS2.
    Unfortunately, ever since, weird things happened: Copy&Paste becomes terrible slow (beach ball), Compressor can’t quit and just by force quit, and many other actions causing terrible long waiting times (beach balling). Now, I read, I should un-install the whole FCS and re-install from the ground.
    My question: When I do this, are all my third party plugs, such as Red Giant, Nattress and so on, also lost and have to be re-installed or they are still around?
    Thanx.
    Sascha
    Sascha Engel replied 14 years, 8 months ago 4 Members · 16 Replies
  • 16 Replies
  • Mark Suszko
    January 20, 2012 at 4:44 pm
    Not lost, if you archived trhem. Just a pain to re-install.
    Don’t forget all the updates to the FCS and quicktime packages. I think I would re-load them in chronological order, as they patch each other’s faults in sequence.
  • Sascha Engel
    January 20, 2012 at 4:47 pm
    [Mark Suszko] “I think I would re-load them in chronological order, as they patch each other’s faults in sequence.”
    What do you mean by that? Don’t get it.
    Archived you mean, if backed the installations for those plug ins up and have to re-run all the installations?
    Thanx a lot.
    Sascha
  • Rafael Amador
    January 20, 2012 at 4:54 pm
    [Sascha Engel] “My question: When I do this, are all my third party plugs, such as Red Giant, Nattress and so on, also lost and have to be re-installed or they are still around?”
    I’m afraid, yes.
    rafael
    http://www.nagavideo.com
  • Sascha Engel
    January 20, 2012 at 4:59 pm
    So, is there anything I can check first, before I’d dive into this Abyss? That it might be solved easier, than full re-installation.
    By the way: will my contents remain, or all those 40gb will be gone also?
    Sascha
  • Rafael Amador
    January 20, 2012 at 5:15 pm
    Hi Sascha,
    I’ve been working with FC.7 installed on top of Fc.6 without problem, but taking care of running DiskWarrior and repairing preferences.
    Anyway, before reinstalling you should make a proper de-installing. I think Digital Rebellion (https://www.digitalrebellion.com/) has a free application to do so.
    The FC’s Application Support folder (Library) will be trashed and with him the Plugins folder.
    You can try to put it somewhere else inside the “Applications Support” but some plugins may not work.
    There are other plugins that install elements out of the FC Plugins folder. I don’t know how may be affected.
    rafael
  • Sascha Engel
    January 20, 2012 at 5:21 pm
    You mean running Disk Warrior over the start up disk? But that is not possible to optimize the start up disk.
    I do run AppleJack very often.
    Repairing preferences? You mean the ones inside DiskWarrior or Disk Utility?
    Why do I need the Plug In of Digital Rebellion? The FCS Remover from FCP itself is not good?
    Sascha
  • Rafael Amador
    January 21, 2012 at 2:11 am
    [Sascha Engel] “You mean running Disk Warrior over the start up disk? But that is not possible to optimize the start up disk.”
    You need to run it from the CD/DVD (slow) or, as I do it, from other computer or external HD with a system installed (Faster)
    [Sascha Engel] “The FCS Remover from FCP itself is not good?”
    There is one?
    Sorry I had no idea on this.
    If there is one, go on.
    rafael
  • Jon Chappell
    January 21, 2012 at 4:02 am
    There is no official Apple uninstaller for Final Cut Studio.
    My software:
    Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
    More tools…
  • Mark Suszko
    January 21, 2012 at 4:57 am
    I’m pretty sure there is, he’s called Walter Biscardi:-)
  • Rafael Amador
    January 21, 2012 at 11:57 am
    [Jon Chappell] “There is no official Apple uninstaller for Final Cut Studio.”
    As far as I know.
    [Mark Suszko] “I’m pretty sure there is, he’s called Walter Biscardi:-)”
    Not sure if is “official’ but works 🙂
    rafael
