Activity Forums Avid Media Composer (Re-) Import lost MXF-Files
  • (Re-) Import lost MXF-Files
    Posted by Mathias Blitz on August 23, 2010 at 10:19 am
    Hello,
    I need some help with the following Problem: I digitized some HDCam Tapes in Avid. After a software crash I had to restart the computer. When I opened the media composer again, the digitized files didn’t appear in the project bin. But they’re still existing on the hard disk as .mxf Files. But it’s not possible to (re-)import them into the avid project.
    Does anybody know how to get these files again into the projoct without digitizing again?
    Thanks for your help!
    Mathias
    Kris Anderson replied 15 years, 8 months ago 2 Members · 1 Reply
  • Kris Anderson
    August 24, 2010 at 5:16 am
    Try this…
    Load your media tool, search only in the project you digitsed the clsps to and only select ‘master clips’.
    It should show the clips in the media tool once it has finished searching. Just drag them to an open bin in your project and you should be ok.
