Activity › Forums › Adobe Premiere Pro › Re: I cannot import AVI or MPEG2 files
  • Vincent Rosati
    August 7, 2007 at 11:40 pm
    To use MPEG-2 in Premiere you’ll need an MPEG-2 codec. Installing MainConcept MPEG Pro will enable you to do this.
    If you’re on a PC, uncompressed AVI should import. If you’re on a Mac, I’ve seen issues importing AVI, use uncompressed MOV for Mac.
    If you could add your system spec’s to your profile that might help us to better answer your issue.
    Hope this helps. : )
