Activity › Forums › RE:Vision Effects › RE: Flex for AE – Morphing to replace missing frames
  • RE: Flex for AE – Morphing to replace missing frames
    Posted by Eugeni Mich on July 20, 2015 at 3:05 am
    When I Correct drifting by modifying tracking settings – If Confidence Is Below 90% – preсom1, after-effects looking bad frame and stops. I’m in the source, after-effects doing RE: Flex for AE – Morphing to replace missing frames, ticks Pikture key, move on to the next frame and turn on a check, and then back to 3 frame back. Again Correct drifting by modifying tracking. For 2000 frames 50 meets problems. How to automate the process?
    Eugeni Mich replied 11 years, 1 month ago 2 Members · 5 Replies
  • Pierre Jasmin
    July 20, 2015 at 4:13 pm
    I don’t fully understand what you ask.
    Are you having the cache issue introduced in AE CC 2014.2?
    If so you need RE:Flex 5.2.1
    “Version needed to run in AE CC 2015 and AE CC 2014. In previous versions, the render cache was not properly re-rendered when masks were modified.”
    Pierre
  • Pierre Jasmin
    July 20, 2015 at 10:42 pm
    Note if this is your question you can set an expression that connects “Picture Key?” checkbox to Tracker motion confidence
    Select “Picture Key?”
    Grab the pickwhip and connect to motionTracker(“Tracker 1”)(“Track Point 1”).confidence
    ETC
    It should work to see if confidence > value; value = 1 else value=0
    (0 is OFF, 1 is ON)
  • Eugeni Mich
    August 20, 2015 at 8:06 am
    Thanks for the quick and clear answer Dear Mr. Pierre.
    Can I send you a short e-mail to techsupport@revisionfx.com?
    With a feeling of deep respect Eugene.
  • Pierre Jasmin
    August 22, 2015 at 5:56 pm
    Sure
    Make sure to attach a beer 🙂
    Pierre
  • Eugeni Mich
    August 23, 2015 at 5:53 am
    Any beer will not replace the fresh smell of jasmine juicy, like splinters, seemingly lost forever happiness, but thanks RE: Flex for AE – Morphing to replace missing frames…
    Thanks again Pierre
