Activity Forums Panasonic Cameras Re: Final Cut settings for Panasonic HVX200 – TAPE
  • Re: Final Cut settings for Panasonic HVX200 – TAPE
    Posted by Iamkleck on October 22, 2007 at 2:36 am
    Hey guys. I just got a new HVX200 camera. I haven’t received the P2 cards yet, so I’m recording on tape too, and when I import the footage it is importing with these wierd scan lines. They are more prevelant when contrast is high, like white next to black, and when there is heavy movement, like waving a hand.
    Is there something I am doing wrong? Could it be the DV camera i’m using to capture? (Sony Handycam)
    I shot in 480i/24p on the HVX200 and tried capturing in FInal Cut using the DV NTSC 48 kHz and the DV NTSC 48 kHz Advanced Pulldown Removal, and my sequence settings are set for NTSC – DV. I would prefer not to use the deinterlace filet if it will make my footage lose quality. Please tell me you can help me out!
    Arnie Schlissel replied 18 years, 11 months ago 3 Members · 3 Replies
  • Michael Sacci
    October 22, 2007 at 4:18 pm
    [iamkleck] “I shot in 480i/24p on the HVX200 and tried capturing in FInal Cut using the DV NTSC 48 kHz and the DV NTSC 48 kHz Advanced Pulldown Removal,”
    If this was your camera settings then you to not have an “advanced pulldown” cadence. You need to either capture and edit 29.98 or shoot in 24pA and then capture as above.
  • Iamkleck
    October 22, 2007 at 6:49 pm
    Yes, I was just trying that in hopes it worked. That still doesn’t explain what is happening when I capture using the DV NTSC 48 kHz though. Those scan lines are driving me crazy! Any other suggestions?? They would be much appreciated.
  • Arnie Schlissel
    October 22, 2007 at 7:16 pm
    You see this on your NTSC monitor? Or just the computer monitor? Your footage is interlaced. You need to view it on an interlaced monitor for it to look normal.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
