Re-entering Serial Number
Posted by Andrew Carlin on May 14, 2010 at 9:01 pmI accidently typed the wrong number serial number, and it won’t let me go back to re-enter it, how do I do this. It just automatically goes the registration online page?
Mark Prebonich replied 16 years, 4 months ago 2 Members · 1 Reply -
1 Reply
Mark Prebonich
May 15, 2010 at 3:49 amDid you try uninstalling and then reinstalling the program? If you are still stuck you should go thru a clean uninstall. Here is the info off of the Sony Knowledgebase site:
Before doing a Clean Reinstall, it is important to do the following:•All audio and video effects chains and presets will be erased, so if you need to make a back up of your presets please download our Preset Manager program. For more information about backing up presets: Backup and Restore Audio Presets | Backup and Restore Video Presets
•Safely disconnect any external USB or Firewire devices like hard-drives or dongles.
•Temporarily turn off ALL anti-virus programs, as well as disabling any Registry Blockers, Spy Ware, Firewalls, etc. These applications have been known to interfere with software installation and registration.
Start the process of removing programs go to Start > Control Panel > Programs and Features – find and remove your Sony Creative Software applications (ACID, Sound Forge, Vegas, DVD Architect, Cinescore, CD Architect or Media Manager, as well as any other Sony Media Software or Sony Creative Software programs).
Also, remove the Microsoft SQL Server Desktop Engine (SONY_MEDIAMGR), any and all Microsoft .NET Framework versions, and the Microsoft Visual C++ Redistributable software if it is listed.
Once un-installed, delete the following folders:
•C:\Program Files\Sony\
(Do not delete this entire folder if you have other Sony applications installed such as Sonic Stage, Everquest, Star Wars Galaxies, etc. If that is the case then only delete the folder for the Sony Creative Software application you are using as well as the Shared Plug-Ins folder.)•C:\Program Files (x86)\Sony\
(Do not delete this entire folder if you have other Sony applications installed such as Sonic Stage, Everquest, Star Wars Galaxies, etc. If that is the case then only delete the folder for the Sony Creative Software application you are using as well as the Shared Plug-Ins folder.)•C:\Program Files\Sony Setup
WARNING: The next step will require you to delete Windows Registry Keys. The Registry is a very sensitive area to work in. If you are not comfortable with advanced configuration and system changes, ask an administrator to help you with this. (Related Topics: How to back up and restore the registry in Windows: https:////windows.microsoft.com/en-us/windows7/back-up-the-registry)Next, open the Registry Editor. Select Start and type REGEDIT in the ‘Start Search’ box.
In the Registry Editor, locate and delete the following registry entries:
HKEY_CURRENT_USER\Software\Sony Creative Software
HKEY_LOCAL_MACHINE\SOFTWARE\Sony Creative Software32 bit applications (like ACID and DVD Architect) installed in 64 Bit Windows 7 will also store registry keys in a different location. Locate the following registry keys and delete them. (Depending on which versions you have installed you may see one or more of these entries. If you do not see all of these, that is normal. Delete those which you do find.)
If you locate a folder labelled “Sonic” please DO NOT confuse this with Sonic Foundry. Leave it alone.
HKEY_CURRENT_USER\Software\Wow6432Node\Sony Creative Software
HKEY_CURRENT_USER\Software\Wow6432Node\Sony Media SoftwareHKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Sony Creative Software
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Sony Media SoftwareClose the Registry Editor.
After removing all of the previous items, you may download and re-install from this link –
https://www.sonycreativesoftware.com/download/updates
When finished with all reinstallation, please restart your computer. When your computer has restarted, you will have a complete clean installation.
I hope this is of some use. I have used this method when I ran into some problems in the past and it worked out fine.
-Mark
