Activity › Forums › Blackmagic Design › re embedded audio via SDI
Posted by Longboy on December 30, 2005 at 6:40 pmIf anyone can show me how to embed audio via SDI for output from Final Cut pro it would be really apreciated. thanks you all
Jonathan Smiles replied 20 years, 9 months ago 3 Members · 3 Replies -
Steve Regian
December 30, 2005 at 10:15 pmAudio is automatically embedded with video via SDI as long as your capture card and deck supports it and you have your project settings set properly. We regularly send/capture audio/video sdi to/from our Digibeta and DVCAM decks as 8 or 10 bit uncompressed via our Decklink Extreme card. You can even override/edit the easy setups to allow a dv timeline to use sdi instead of firewire. Make sure your deck inputs are set to input sdi, not firewire or analog.
Jonathan Smiles
January 2, 2006 at 9:23 amYou audio output device should be set to DeckLink Audio.
Jonathan Smiles
Managing Director/CEO
Digital Safari Ltd
UK – Specialist Reseller
dCinema – HD – SD
https://www.digitalsafari.co.uk
