Activity Forums Adobe After Effects Expressions Re: Effect Point Control Question!! Wisdom needed.
  • Re: Effect Point Control Question!! Wisdom needed.
    Posted by Rick Makoul on January 26, 2007 at 7:57 pm
    I tracked a headlamp on a CG car and need to add this Tracked info. to an Effects Control point and or through expression to the XY coordinates of a lensflare effects XY. Can anyone guide me to get this done correctly in AE?
    Thank you
    Mike Clasby replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mike Clasby
    January 27, 2007 at 1:58 am
    Unless I’m not understanding you, you just need to Copy/Paste the Track Pont 1 Feature Center keyframes into the Lens Flare> Flare Center property (same layer), no expression needed.
    Or, with expressions, you can Alt click the Flare Center stopwatch and pickwhip to the Feature Center of the aforementioned track), giving you this expression:
    motionTracker(“Tracker 1”)(“Track Point 1”).featureCenter
    Then if you wanted to offset the flare a given distance from the trackpoint, you could add “value +” to you expression giving:
    value + motionTracker(“Tracker 1”)(“Track Point 1”).featureCenter
  • Mike Clasby
    January 27, 2007 at 1:59 am
    Oopps, after you add the value +, then drag the lens flare to the amount of offset you want, then the expressions will keep it the same offset distance.
