Activity Forums VEGAS Pro re-editing a project
  • re-editing a project
    Posted by Chris Callaghan on August 26, 2009 at 6:22 am
    Ive done a multi-cam project and now the performer wants me to go back and bring up a segment I edited out.
    I know roughly where the segment is, but I can’t seem to expand that part of the project so I can find the segment.
    I need to expand the multi cam track, the sound track and a few other duplicate tracks that aren’t part of the Multi cam track
    Can anyone here put me on the right path?
    John Rofrano replied 17 years ago 2 Members · 5 Replies
  • John Rofrano
    August 26, 2009 at 11:32 am
    When you say “multi-cam track” are you referring to the track that Vegas Pro combines all of your tracks into? And when you say “expand” do you mean that you want to get them back into multiple tracks? If so, the answer is… you can’t. It’s a one-way process. 🙁
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Callaghan
    August 27, 2009 at 12:33 am
    Hello John,
    Thanks for responding.
    The Multicam track is the combined track created when I selected particular tracks to make into a multicam track. This left a number of other tracks untouched, such as audio and a few duplicate video tracks.
    When I did the mutli cam edit, to remove any unwanted segments I would split ALL of the tracks somewhere near the edit point , slide them against each other and continue editing the multi cam by taking which shot I needed.
    This got rid of chunks of unwanted material, such as chatter between songs etc.
    Now I want to “un-slide” these tracks apart. I know I can’t separate the individual tracks, which is why I left the sound tracks out of the multicam.
    How do I go about selecting ALL tracks and “unslide” them apart, to see the segments that I removed?
  • John Rofrano
    August 27, 2009 at 11:19 am
    The easiest way is to turn on Ripple Edit (Ctrl+L) with the All Tracks, Markers, and Regions option. Then move an event on the multi-camera track to the right and all related events on all other tracks will move with it opening up a gap. Then turn ripple edit off and extend the events to reveal the cutout material.
    ~jr
  • Chris Callaghan
    August 29, 2009 at 2:46 am
    Hi John,
    thanks for putting me straight on this. The trick is indeed turning ripple edit on, turning ALL tracks on and then dragging to the right.
    I was getting stuck by leaving ripple on, instead of turning off and then opening the “hidden” segments. Again, thanks very much.
  • John Rofrano
    August 30, 2009 at 1:35 pm
    Yea, ripple edit should be used sparingly. It can have some nasty effects if you keep it on all of the time because it may move things you never intended to move. Used sparingly it’s a great aid in editing. Glad that helped.
    ~jr
