Activity › Forums › Panasonic Cameras › Re: Dubbing P2 Footage via Firewire to DVCPROHD Tape
  • Re: Dubbing P2 Footage via Firewire to DVCPROHD Tape
    Posted by Arjun Rao on May 21, 2007 at 10:33 pm
    Hello All,
    I would like to know if any one has output footage from the P2 to DVCPROHD Tape using firewire. We have 1080 24psf footage that we need to transfer to DVCPROHD tape.
    Sincerely,
    Arjun Rao
    David Jahns replied 19 years, 4 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    May 22, 2007 at 2:13 am
    Are you having trouble with this?
  • Arjun Rao
    May 22, 2007 at 6:44 pm
    The footage i have is 1080 24 psf and i have to output to tape 1080i . Can this be done using the firewire route?
  • David Jahns
    May 23, 2007 at 8:20 pm
    via firewire, the answer is NO – can’t do. FW & DVCPro HD won’t support 1080p.
    if you have a KONA 3 or LH card, you can tell FCP to use the KONA’s 1080i video output, and it will add the 2:3 pulldown for you. Of course, this means HD-SDI output and a deck that can record it.
