Activity Forums Web Design (WordPress, Joomla, etc.) RE: display html page I frame on another page
  • Curtis Thompson
    February 25, 2010 at 8:15 pm
    hello…
    something like this in the framed page should do the trick…
    https://htmlhelp.com/faq/html/frames.html#frame-context
    sitruc
  • Harrison Willett
    February 28, 2010 at 4:24 am
    iframes work great when you do not own the content (example: you are using an application provided by a different source then your own and they do not want to give you the API)
    In your instance you are using the IFRAME to try to create a fun scrolling effect instead you should try the fallowing:
    <div style=”height: 556px; width: 955px; overflow:auto;”>
    content goes here
    </div>
    This will create the same effect the content will actually be on your page which will help with search engine optimization.
  • Yuriy Krapivko
    March 3, 2010 at 6:13 pm
    Page with a slide show does not work (404): (If you have problems on work in html – Welcome to html tutorials.
  • Peter Usle
    March 3, 2010 at 9:55 pm
    Thank you everyone, Thanks’ for that link Curtis. We
    turned off the slide show, that’s why the 404 error, Yuriy.
    We used your info Harrison, and we now have a signal page,
    so awesome! As soon as we get our pics back up on Google
    Images we’ll check the links. The Forum has saved us hours
    of frustration, thanks’ again Harrison it worked great.
