Activity Forums Apple Final Cut Pro Legacy Re-Digitizing
  • Posted by Terry Moore on June 8, 2007 at 12:50 pm
    How do I re-digitize clips with new parameters? For example, I have several clips that I digitized with Audio 1 only. Later I realized that I need Audio 2 as well.
    How do I modify the clip to include A2 so I can just re-digitize the clip quickly and easily?
    -Logan
    Terry Moore replied 19 years, 3 months ago 3 Members · 4 Replies
  • Russell Lasson
    June 8, 2007 at 2:36 pm
    Though I’ve tried, I haven’t figured out how to do that. My work around is just to create a new clip with Log and Capture with the same in and out points.
    -Russ
  • Robert Garry
    June 8, 2007 at 10:25 pm
    Set your Caputre setting in the Log and Capture window for the parameters you wish to capture. Then select the clip(s) you want to recapture and when the system prompts you choose to Ignore logged settings and instead check the the box to use the Current capture settings. This will override the logged parameters and base its’ capture off of whatever settings you have chosed in the L&C window.
    Good Luck
    Bob
  • Russell Lasson
    June 9, 2007 at 5:26 pm
    Sweet! I’ll have to give that a try.
    -Russ
  • Terry Moore
    June 11, 2007 at 2:35 pm
    Thanks for the info!
