Activity › Forums › Media 100 › Re-digitizing legacy bins in i
  • Re-digitizing legacy bins in i
    Posted by Bobby Mosaedi on April 8, 2005 at 7:12 am
    heres the scenario: i have a bin from many moons ago where clips were logged and dig-ed at 640rez 44.1 and i have the original source tape to redig from except this time i my time line is in 720 48k, when i go to batch digitize all i get is an empty queue with digitize ghosted. If i change media standard to 640×480, thne my clips reappear in the batch dig window. Why cant i force redig in 720? any workarounds? i tried exporting powerlog but only thing i can manipulate is if i want tracks to digitize and the in-out points.
    its 2:10AM, i dont feel like relogging all those clips if i dont have to.
    Floh Peters replied 21 years, 5 months ago 2 Members · 3 Replies
  • Floh Peters
    April 8, 2005 at 7:20 am
    You either could export the bin as a PowerLog file and reimport it again, or you can set your hardware settings as you want them to be, select everything in your bin, press CTRL-CMD-ALT-Shift while selecting batch reacuire (hold the keys through the warning messages). CTRL-SHIFT is to force redigitizing of video at the current hardware settings, ALT-COMMAND is for forcing audio to redigitize at current settings.
    Btw, you should be able to mix 640 and 720 Media 100 i clips in the same timeline.
  • Bobby Mosaedi
    April 8, 2005 at 6:23 pm
    Thank you thank you
    [Floh] “Btw, you should be able to mix 640 and 720 Media 100 i clips in the same timeline”
    btw, floh, i forgot to mention this is on my xs 8.2.2 system. Im assuming that statement refers to 10.0/.1?
  • Floh Peters
    April 8, 2005 at 6:29 pm
    [Bobby Mosaedi] “Im assuming that statement refers to 10.0/.1?”
    Yes
