Activity › Forums › Apple Final Cut Pro Legacy › Re-digitizing a sequence
  • Re-digitizing a sequence
    Posted by Scott Witthaus on December 2, 2005 at 5:38 pm
    Hey all –
    A client is bringing in a short film that he cut on FCP from time code matching DV dubs of film transfer on Dbeta. He wants to now ‘uprez’ his project from the dbetas, uncompressed. I will get his project file and final sequence on a CD, no media.
    What is the best way to handle this and what are the ‘gotchas’ that I need to look out for? I am assuming all effects will be in place (need to re-rendered), but will title media work? Any advice on this workflow would be appreciated.
    sw
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    Greybox, LLC
    Richmond, VA USA
    http://www.greybox.cc
    Dan Riley replied 20 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    December 2, 2005 at 5:58 pm
  • Dan Riley
    December 2, 2005 at 8:53 pm
    A newer version of what Shane posted is here and I use it with FCP5
    with no problem.
    https://www.kenstone.net/fcp_homepage/basic_onlining_jordan.html
    Titles will come through. Transitions will come through if they
    were from FCP and not some plug the other editor had on his system.
    Still frames will not always come through. You may have to recreate them.
    You will see the timecode number of where the still frame occurred on the
    clip title.
    Speed changes will not come through. You will need to find out
    what was there. Hopefully he’ll give you a copy of his offline
    to see what needs to happen.
    Bottom line is, FCP is not foolproof when it comes to uprez,
    but if you follow the directions in the link above, it will be
    pretty good. FCP is NOT an AVID when it comes to this, sadly.
    My workaround has been to just do less finishing in the offline
    and wait until the uprez to it. The client doesn’t
    get as polished an offline but it makes getting the project done
    and through the uprez much easier.
    Dan
