Activity Forums Apple Final Cut Pro Legacy Re-digitize from 8-bit uncompressed to HDV
  • Re-digitize from 8-bit uncompressed to HDV
    Posted by Jerry Alto on January 8, 2009 at 5:28 pm
    OK, I know I can do this (in fact I think I’ve done it) but for some reason I can’t get it to work.
    I want to take an 8-bit uncompressed SD sequence in an 8-bit uncompressed FCP project and re-digitize the sequence in HDV.
    Things I’ve tried.
    Created an HDV sequence inside the 8-bit project and copied and pasted the 8-bit sequence clips into the HDV sequence and tried to re-digitize in HDV. Doesn’t work.
    Media managed the 8-bit sequence using re-compress (HDV). Doesn’t work.
    Created an HDV project and pasted the 8-bit sequence into an HDV timeline to re-digitize. Hasn’t worked.
    Does anyone have the workflow on this? Any help would be appreciated.
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
    Jerry Alto replied 17 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    January 8, 2009 at 6:15 pm
    use the media manger to “Create Offline” of your sequence and send that to a new project with HDV settings.
    When that new project opens up, recapture the media in the bin with HDV and then it will relink to that new sequence.
    Jeremy
  • Jerry Alto
    January 9, 2009 at 12:45 am
    Jeremy- Thanks Jeremy… it worked… at least for half of the clips. The workflow was right…. it is just dealing with HDV time code/control track. Unless you have 10 seconds of pre-roll forget it.
    I kept getting stuck on the re-compress option in media manager.
    Thanks for your help.
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    Sony Z-1
    GV-HD700
