Activity Forums Apple Final Cut Pro Legacy re: de-interlacing DV Pal footage
  • re: de-interlacing DV Pal footage
    Posted by Joel Maslin on October 5, 2006 at 3:45 pm
    Hi
    I am capturing some mini DV footage (that I did not shoot) and if I capture it with the DV Pal settings switched to progressive it still seems to give me interlaced footage. I am making sure my capture settings, timeline settings and export settings (when exporting a Quicktime movie as DV pal) are all the same. What can I do to stop the interlacing which looks terrible on quick camera moves? I have tried using the standard de-interlace effect but the result is too low quality. Any help would be greatly appreciated.
    Many thanks,
    JM
    Joel Maslin replied 19 years, 11 months ago 2 Members · 4 Replies
  • Ed Dooley
    October 5, 2006 at 3:58 pm
    Is the original footage progressive, or are you just trying to make interlaced footage progressive
    while you capture it? Are you viewing it on a video monitor, or your computer monitor?
    Ed
    [northern] “I am capturing some mini DV footage (that I did not shoot) and if I capture it with the DV Pal settings switched to progressive it still seems to give me interlaced footage. I am making sure my capture settings, timeline settings and export settings (when exporting a Quicktime movie as DV pal) are all the same. What can I do to stop the interlacing which looks terrible on quick camera moves? I have tried using the standard de-interlace effect but the result is too low quality. Any help would be greatly appreciated.”
  • Joel Maslin
    October 5, 2006 at 4:10 pm
    Hi Ed.
    Many thanks for your reply.
    The original footage would seem to be interlaced and I would like to try to turn it progressive as I capture it if i can. I am viewing it on my computer monitor. Ultimately I would like to end up with an .avi which dosen’t look interlaced.
    Best,
    JM
  • Ed Dooley
    October 5, 2006 at 5:53 pm
    By just de-interlacing your footage you’ll lose half the resolution, which you really don’t want to do.
    Nattress filters do it without losing resolution, by blending the 2 fields together:
    https://www.nattress.com/Products/filmeffects/filmeffects.htm
    There are also other filters, as well as workarounds that don’t work quite as well, but are free, do a search of posts in the forum
    for deinterlace and it will turn up hundreds of posts.
    Ed
  • Joel Maslin
    October 6, 2006 at 9:29 am
    Hi Ed
    Thanks for your reply, I’ll investigate some of these filters.
    Have a nice day
    Best
    JM
