Activity Forums Adobe Premiere Pro re: CS3 using Decklink HD extreme capture card / Intensity c/c
  • re: CS3 using Decklink HD extreme capture card / Intensity c/c
    Posted by Nicola Burke on September 10, 2008 at 10:46 am
    Hello,
    System is:
    Microsoft windows xp
    professional
    Version 2002
    Service Pack 3
    Intel(R)
    Pentium (R) 4 CPU 3.40 GHz
    3.41 GHZ, 2.00 GB or ram
    Software is:
    CS3 Adobe
    Question 1
    The questions is has anyone used the new Decklink HD Extreme with Adobe CS3 or the Intensity from Black Magic. Wil my machine be compatible with the new Decklink HD extreme? or the Intensity ?
    I was using Prem Pro 1.5 with the matrox rtx.100 extreme – which will not work with CS3 without up-grading to the new Matrox – which is not an option at the moment.
    Question 2
    On my system I still have the adobe prem 1.5 and matrox rtx100.extreme – I can capture with these and then import them into CS3 is this a good option?
    Any help from anyone out there will be much appreciated. Thank you in advance. Kind regards, Nik
    Nicola Burke replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
