Activity › Forums › Apple Final Cut Pro Legacy › re-connecting media, file-by-file-by-file…
  • re-connecting media, file-by-file-by-file…
    Posted by Bob Cole on January 17, 2009 at 1:46 am
    Started a project on a MacPro, ran out of time and had to leave town for a job. I decided to copy the project file onto my MacBook Pro, and the folder containing the media files to an external hard drive.
    I thought, based on past experience, that it would be a snap to reconnect the media. But I discovered two weird things:
    1. About half the time, FCP told me that the file to reconnect had the right name, but the wrong start and end. Did I REALLY want to connect this file? Of course – and it worked fine. So, why the error/warning message?
    2. Although I checkmarked the box to reconnect all other files in the path, FCP didn’t do that even once. I had to reconnect every single file.
    So what did I do wrong here?
    bob c
    Jerry Hofmann replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    January 17, 2009 at 2:38 pm
    You didn’t use the media manager to copy the files… that works just fine for me when reconnecting… because you don’t have to at all! Just create a new project file during the process from the Media Manager’s window and it will be already connected to the copies.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
