Activity Forums Maxon Cinema 4D Re-connect a newly editable object to its caps
  • Re-connect a newly editable object to its caps
    Posted by Ryan Paterson on November 19, 2014 at 8:26 pm
    For some reason when I converted a cylinder to editable the polygons of the caps became separated so I cant bevel them. What tool/command do I use to re-connect the points? Thank you!
    Ryan Paterson replied 11 years, 9 months ago 2 Members · 2 Replies
  • Emir Bojorquez
    November 19, 2014 at 8:47 pm
    In Polygon Mode, select all >>Right Click >>Optimize.
    Good Luck
    Imagination is the best tool…
  • Ryan Paterson
    November 19, 2014 at 8:50 pm
    Perfect, thank you!
