Activity Forums Apple Final Cut Pro Legacy re capturing
  • Posted by Phil Gravy on November 11, 2005 at 10:16 pm
    when i went and loged then captured some video the audio was not selected so theres no audio for the video that ive captured so is there an easy way to recapture the footage with the audio since ive allready tried recapturing with the audio box selected
    Todd Gillespie replied 20 years, 9 months ago 2 Members · 1 Reply
  • Todd Gillespie
    November 15, 2005 at 7:22 pm
    Hi Phil,
    You can get the audio, but FCP will recapture the video as well.
    Open log and capture window and check audio, the Select batch capture on the clip/clips, then when the Batch Capture window comes up UNCHECK options ‘Use Logged Clip Settings’
    It will add the audio files to your clips
    Good Luck,
    Todd at UCSB
    Television Production
