Activity Forums Apple Final Cut Pro Legacy Re-capturing old sequence… problem
  • Re-capturing old sequence… problem
    Posted by Joel Matthew on November 4, 2005 at 6:19 pm
    I went through the steps Joe listed yesterday (below) but when I batch capture in the new project, it still indicates it needs 24 GB – even though the actual sequence I’m trying to recapture is only 4 minutes…
    Thanks for any more ideas.
    Joel
    “Right click on the sequence and select “make clips independent”. The use media manager to make an offline of the project. Batch capture in the new project and it will only grab what you need.
    joe”
    Sean Oneil replied 20 years, 10 months ago 4 Members · 6 Replies
  • Jerry Hofmann
    November 4, 2005 at 7:06 pm
    You also need to turn on the option to “delete unused media”…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Joel Matthew
    November 4, 2005 at 7:17 pm
    Thanks Jerry – just tried that, and unfortunately, still seems to be wanting to capture more than is needed for this sequence.
    Other clicks?
    Joel
  • Joe Paolo
    November 4, 2005 at 8:21 pm
    Just curious– if you check your clip bin in your new project, are the durations what you’d expect for each individual clip or do they seem to long?
    joe
  • Jerry Hofmann
    November 4, 2005 at 8:47 pm
    Is the old media still online? If not that’s the problem… Media Manager expects the media to be online when deleting unused media is used to create a new offline sequence.
    Jerry
  • Joel Matthew
    November 4, 2005 at 11:10 pm
    Joe – the bin, “Master Clips…” looks like appropriate lengths for the clips.
    Jerry – the media hasn’t been on the system for months. It’s all offline.
    Anyway – here’s how I worked around it – I exported the EDL. Imported the new EDL into a new project and batch captured for that. Comes in pretty well. A few tweaks required, but a lot less time than remaking it!
    Thanks for your help along the way. And I would be curious if there’s a better way.
  • Sean Oneil
    November 5, 2005 at 9:30 am
    Joel, unfortunately you’re screwed. This is a known design flaw with Final Cut. If the media is already offline, it cannont “delete unused media”. Idiotic, stupid, and just plain wrong are what comes to mind everytime this issue comes up. I really wish they’d fix it. I urge you to leave feedback to Apple regarding the matter.
    Sean
