Re-Burn or Copy?
Posted by Vegasarian on August 19, 2006 at 7:45 amI have been asked by a client to supply a second copy of a DVD I prepared last week. I still have the project in Architect and it will be easy enough to remake a second DVD but I’m just curious to know if I made a copy of the original DVD with 1 Click or Intervideo would I take a quality hit?. Which is best option?.
Riredale replied 20 years ago 4 Members · 6 Replies -
Mike Kujbida
August 19, 2006 at 11:15 amI use RecordNow to do this all the time as I don’t have the room to keep the master project for very long. I just set it up to make a data DVD, copy the original VIDEO_TS & AUDIO_TS folders to my hard drive and make as many copies as necessary.
Edward Troxel
August 19, 2006 at 1:30 pm -
Vegasarian
August 19, 2006 at 1:58 pmYea I have no problem to do that Ed I was just curious to know if DVD Copiers actually make exact copies with no quality loss. Now I’m also curious about your procedure Mike. You make a data dvd in Record Now and save your Video TS and Audio TS files in it?. Whats the benefit over saving a copy of the DVD and just making copies from it as needed?. Or am I being thick?.
Edward Troxel
August 19, 2006 at 2:23 pm -
Riredale
August 27, 2006 at 4:50 pmI have found that even if there is a DVD that won’t play properly in a DVD player, I can make a clean copy that will play. I think the reason is because the reading software on a PC is much more aggressive in getting the data off the disk, and will slow the drive down and read the disk multiple times until it’s satisfied. Once you have a clean copy of the VIDEO_TS folder, you can burn clean new copies.
