Activity › Forums › Apple Final Cut Pro Legacy › Re: best slow motion plug-in for FCS2
  • Re: best slow motion plug-in for FCS2
    Posted by David Mcgiffert on February 8, 2008 at 5:26 pm
    Well, I guess the subject line says most of it…
    I want to slow down some HDV footage shot with a Canon XH-A1.
    I have used Twixor in the distant past, is this currently still
    the best option?
    Thank you,
    David
    Jamie Kehoe replied 18 years, 5 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    February 9, 2008 at 5:25 pm
    Try Motion 3 instead… best? dunno, but better than FCP in a heartbeat. It uses a ton better code for slow motion effects.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Mcgiffert
    February 9, 2008 at 8:46 pm
    Thank you Jerry.
    I am not sure how to do that in Motion,
    but I guess that’s why they made manuals.
    (putting on reading glasses and opening manual…)
    David
  • Jerry Hofmann
    February 9, 2008 at 11:03 pm
    Report back with your experience in this thread!
    Jerry
  • David Mcgiffert
    February 10, 2008 at 3:37 am
    Jerry,
    I am about the worlds worst person to have messing
    around in Motion and then reporting results…I don’t know
    it well at all.
    Here is what I did find out sofar. I tried a very jittery
    handheld shot in Motion’s smoothcam-like behavior’s setting.
    The result was stunningly effective.
    Now I don’t exactly know what I did, but I came up with a clip that was MUCH better looking then what I started with.
    The thing that is cool is that you can keep the clip running and
    mess with the parameters in real time…now that is impressive.
    What do I even LOOK for to slow down a clip down in Motion?
    (face red),
    David
  • David Mcgiffert
    February 26, 2008 at 6:50 am
    Jerry,
    it’s a little late on the topic,
    but I have now gotten familiar with Motion’s ability
    to slow a clip and I think it is fantastic.
    Thanks for pointing the way.
    David
  • Jamie Kehoe
    April 30, 2008 at 8:52 am
    To slow down footage, there are numerous ways using a multitude of plugins or techniques, but in Motion, you do that through the Timing section. For blending choose Optical Flow and then set your percentage at anything slower than 100%. Depending on if you want to have a Matrix effect, slow down and speed up, you will need to play around with keyframes and timing of each section. Keep in mind you need to work on smaller sections of video as it is very slow to render unless you have a really fast Mac Pro Workstation.
    G5 Dual 2.3GHZ
    2.5GB DDR SDRAM 400MHZ
    Mac OS 10.5.1
    2 x 20″ Apple Cinema Display
    128MB ATI Graphics
