Activity › Forums › Adobe After Effects Expressions › re: Bacteria
re: Bacteria
Posted by Royston on November 1, 2006 at 2:56 pmHi
Does anyone know how I can create bacteria as you would see it under a microscope.
Thanks in advance for all the repliesRoyston Michaels
Royston replied 19 years, 11 months ago 2 Members · 4 Replies -
Chris Smith
November 1, 2006 at 7:56 pmI did bacteria like effects once. I used Maya but the same applies to any other 3D program. I created a bunch of randomly placed particles. Wrote a simple expression that made them move each with their own noise function. Then for the render assigned an instance of simple blob like geometry to them. Then lastly used Blobby Particles (Also called “Metaballs” in other apps) to make them fuse together when they got close to each other. Then lastly create a shader that gives the look you want. Here’s where you can make it look like electron microscope or just “realistic” as if the camera was down in their world. It looks quite creepy in the end.
Chris Smith
https://www.sugarfilmproduction.com -
Royston
November 2, 2006 at 9:11 amThanks for the replies. I did a search on BBC motion gallery for micro shots…maybe it will help you with a reference to what I’m trying to achieve. It’s the blue clip.
Royston Michaels
Royston
November 2, 2006 at 9:13 amSorry didn’t specify which blue clip…it’s the second clip next to the red one.
ThanksRoyston Michaels
Royston
November 3, 2006 at 6:57 amHi Dave
here is the link
https://www.bbcmotiongallery.com/Customer/SearchResults.aspx?searchText=micro+shots&type=SimpleIt’s clip 2896-2
Hope this helps.
Royston Michaels
