Activity Forums Apple Final Cut Pro Legacy re-associate independent clips
  • re-associate independent clips
    Posted by Kimberly on May 11, 2005 at 6:15 pm
    “If a master clip linked to the same media already exists: Independent clips that are linked to the same source media on disk become affiliates of these preexisting master clips.” pg. 283
    I am trying to re-associate independent clips from my sequences with thier respective master clips.
    All of my master clips are organized in bins within the same project as my sequences.
    When I use the ‘create master clips’ tool, it only manages to recreate all of my master clips, without re-associating any of them with the ones already in my project.
    Am I interpreting the manual wrong? Is there another way to re-create an association from an independent clip with a master clip already in the project?
    Thank you for your help.
    Kimberly replied 21 years, 4 months ago 1 Member · 1 Reply
  • Kimberly
    May 11, 2005 at 7:20 pm
    “When Can Independent Clips Become Affiliated With Existing Master Clips? For an independent clip to become affiliated with a preexisting master clip when using the Create Master Clips command, the following criteria must be met: The master clip must contain all tracks that are used by the independent clip. The master clip must contain all of the frames used by the independent clip. Essentially, all media used by the independent clip must exist in the master clip. Otherwise, it
