Activity › Forums › Adobe After Effects › Re Applying Trackers
Posted by Angel Nieves on June 9, 2010 at 4:03 amHow can I apply a tracker again? I tracked a layer, and after I had applied it to a layer, I decided I needed to extend the tracking. If I go to the tracker, it lets me track the shot starting from the last tracked frame, but when it stops, the apply button is grayed out. How do I apply the added tracking to the layer?
Stuart Elith replied 16 years, 2 months ago 3 Members · 7 Replies -
Roland R. kahlenberg
June 9, 2010 at 5:08 amDid you remove the target layer from the comp?
Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
Angel Nieves
June 9, 2010 at 1:40 pmNo I didn’t. But I tried different things, including replacing the old target with a new one. Nothing worked. Why can’t I re-apply the tracker?
June 9, 2010 at 2:47 pmSorry dude, I can’t figure this out. Perhaps you can restart the track. Of is you’re in the zone, you’ll create a new tracker and know how to copy/paste the Attach Points from the two trackers onto a single targeted property.
Of course, you have the option to start a new tracker from the beginning.
Good Luck
Roland KahlenbergSell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
Angel Nieves
June 9, 2010 at 11:43 pmThat’s not it, either. I’ve been trying in the layer window. Can this be done? Re-apply a tracker?
Angel Nieves
June 10, 2010 at 7:05 pmNo, that is not going to work. I need to extend the tracking. It tracks the additional frames but then I can’t apply the new tracking. Don’t know what the point is of allowing you to access an old tracker and add to it, but then you can’t apply it.
Stuart Elith
June 11, 2010 at 6:21 amSomething unusual is happening in your circumstance, because you definitely can continue working with a tracker once you apply it the first time. I did it just yesterday… went back and realised I needed to track more of my clip, so I continued tracking then re-applied the new (extended) tracking info to my solid. Worked fine.
So perhaps there is something glitchy happening, or there’s something else at work.
If you do a test with a new track, applying it, changing the track then re-applying, see what happens. Maybe something just bugged out in this circumstance.
