Activity Forums Adobe Premiere Pro Razor tool issue
  • Razor tool issue
    Posted by Tod Geddes on January 30, 2018 at 4:38 pm
    I have the latest version and updates to Premiere Pro.
    I uploaded and did a rough edit using the Rolling Edit tool.
    Once the editing was approved I went back to the rolling edit points and used the razor tool to cut the excess… everything appeared fine, till I tried to put a transition over the cut point and it would place the transition on only one of the clips, not both. I checked the razor cut point and found that the footage that should have been removed was still there… I tried removing it several times, saved and rebooted the program and still the same.
    Any clues??
    Thanks for the assistance
    Ann Bens replied 8 years, 7 months ago 3 Members · 2 Replies
  • Eric Merklein
    January 30, 2018 at 6:15 pm
    It may be easier to use keyboard commands:
    1- Add edit (which actually means make a cut, or splice) where your in point and out point is located.
    2- Mark the new clip
    3- Extract
    Never fails.
    Eric
  • Ann Bens
    January 31, 2018 at 12:48 pm
    The clip that does no contain the transition probably has no handles.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
