Activity Forums Adobe Premiere Pro razor cut on the fly?
  • razor cut on the fly?
    Posted by Scott Childress on July 5, 2009 at 4:28 pm
    I know Ctrl K cuts at the time indicator, but is there away to do this without CS4 pausing the timeline?
    Working on a music montage with black video inserted, cutting clip at the beat and then replacing black clips with video and stills, should be a quick job if the timeline would not pause every time I cut with the razor….
    Koby Goldberg replied 17 years, 2 months ago 2 Members · 1 Reply
  • Koby Goldberg
    July 5, 2009 at 10:16 pm
    Scott,
    I don’t know if it is possible to tell PPRO not to pause each time you press CTRL+K… But I can offer another way for you to achieve what you want:
    Play the sound and place Markers using the * on the numeric keypad while hearing it. The * does not pause the playback. After finishing the whole music, just jump between the Markers by holding the CTRL and pressing the right or left arrow key, and press CTRL+K to place a cut. Therefore you can hold the CTRL key down, and just press interchangebly: arrow, K, arrow, K, arrow, K … in order to place a cut and then jump to the next Marker.
    Koby
